LLY: Twin turbo oil temp solutions/turbo size questions.
dirtymax36
2nd place is last
Apr 11, 2013
367
Came across a steal on a twin kit for my lly. I'm run in a dts 71.5 now. The charger with this kit is a 75/88/1.32 s400 Billet. Would that be too small to work on my set uP? Just keeping my options open. Not really wanting to purchase a s488 out right at the moment.
Also what oil cooler set ups are you guys running to keep the temps down? Right now I see 180 or so with hicks 15w40.
st461
Apr 4, 2014
3
oil temps
"Killer Bees" oil cooler. Expensive, more trouble than usual to buy and receive it but, it looks and works great. Barely gets to 180 on the Gulf coast with 480/366.
Verlon at ATP
Mar 19, 2015
165
I agree on the oil cooler. I run Killer bees setup and I find it a must have when towing heavy with twins. He is a pain to get a hold of and deal with though.
I don't think you will find much benefit from a 75mm atmosphere turbo with your current turbo. An 82mm would be a much better match.
PACougar
2,105
41
El Dorado Hills, Ca
A s475 would be way too small to pair up with your current turbo. You can add your own external oil cooler yourself for a reasonable amount of money. Realistically tons of people are running twins and towing without adding more oil cooling and it's working just fine.
dirtymax36
2nd place is last
Apr 11, 2013
367
Thanks for the info PA. you make a good point there are a lot of stocker twin guys running around stock. But, they do not have the cash sunk unto a built motor and they probably won't see the extreme abuse this truck is capable of.
I've searched around, is there any pieced together info on DIY coolers? Not looking to drop 1k on killerbees set up.
Thanks
baggedLB7
Goer
May 1, 2011
688
Utah
5,911
Thanks
you didnt look very well ;) :thumb:. i have lots of info/post on my temps and differences between no air to oil cooler and after one is added. im a built motor, stocker over 80mm turbos and tow alot in AZ summers on a 600rwhp tune. bhoward does the same with a heavier load than me as well as Verlon. :D
moparkxracer
2,309
33
Out and about
I am using a sandwich adapters and a Fluidyne cooler. I do not have any issues with oil temps.
picture.php
countrycorey
Trust Me I'm an Engineer
Jan 30, 2010
1,512
35
LA
How much difference is there in oil temps between your ball bearing turbos and a journal bearing setup?
Corey
dirtymax36
2nd place is last
Apr 11, 2013
367
I do not know much about ball bearing ones except they do not require as much oil to operate and some are water cooled which is why the oil temps could be lower on them.
Off hand, does anyone know a good asking price for a brand new billet 475 like this? I'll be selling this one looking for a bigger s400 for my rig. Thanks
dirtymax36
2nd place is last
Apr 11, 2013
367
I agree. Using another liquid to take some of the heat off the engine oil will lower oil temps naturally, but having another water cooled turbo could then raise your ECT. hand in hand relationship
