I figured I'd seperate the compounds build from my engine thread. Started ordering parts last week and they started showing up today.
So far I have in possesion:
Turbo
Turbo blanket
S400 vband for hot pipe
Turbonetics outlet vband
Triple pillar pod
Boots, hoses and clamps
Oil feed and return line
And a few pieces of the pipe I ordered.
Everything else should be here by Wednesday or Thursday this week.
Still waiting on:
100 psi boost gauge
Remaining pipe
Coolant tank (picking it up in the morning)
I'll be putting a custom turbonetics y2k 88mm over my billet s472.
Specs on the turbonetics:
88mm hpc billet wheel
101/112mm turbine
1.23 ar turbine housing
Ball bearing
Hot pipe between turbos will be 304 stainless, charge pipe is mild steel and downpipe will be made from aluminized steel that I had laying here.
Can't wait to get this started. As far as I'm concerned, I can get the turbo mounted, oil lines hooked up and down pipe built until the rest of the parts show up.
Turbo
Turbo blanket
Triple pillar pod
Still waiting on:
100 psi boost gauge
Remaining pipe
101/112mm turbine
Ball bearing
