twin turbo build question
hd2500
Oct 1, 2013
Hey guys, im adding a s475 to my lb7 daily driver. I believe i have everything i need, but had a question. since this is my daily driver, i am planning on building a few parts on my days off and have it finished in about a week. can i mount the turbo and run oil lines to the turbo, and then make the intake pipe between turbos, relocate maf, and make an intake, but still run the truck? basically just having a useless turbo without the hotpipe done, in the engine bay for a day or so, but still be drivable?
03spoolindmax
Nov 9, 2011
674
Mi
Sounds like a bad idea.
Why don't you just make a section a little at a time but take it off after you've made it until you get a whole kit.
That way you don't have half a kit that doesn't work hooked up.
dirtydmax
<---up shit creek
Sep 1, 2013
1,091
46
muskoka,Ont Canada
Im doing the same setup you are doing and trying to gather parts,What are you using for the pipes,Size for intermediate,down and intake?Is it a bend kit or old exhaust like im doing,I have never seen a twin kit up close and personal to get an idia and going only on what I have learned on DD.Pm me if possible.Thanks:thumb:
Oct 16, 2008
948
12
Idaho
Keep the turbo mounted in there but if it were me I would remove the new cold pipe and put your intake back on if you drive it. I don't see it causing any major issues the way you described it beyond it might raise hell with your maf sensor readings. You might also get some oil seepage past the turbo seal since they need positive pressure.
hd2500
Oct 1, 2013
dirtydmax i'll pm you some information. and thank you everyone for the responses.
