Turn Signal Help
contenderv07
68
Need some help with this one... I installed some tow mirrors (heated, power, turn signal)tested and worked fine. Got back in to test again and nothing. The weird part it's just the right signal. Left works fine, when I hit the hazard, its just the left. When I hit the signal to turn right, I don't even get the blinker noise. I went back in the door panel and reconnected everything but the same result. WTF is going on??
** Just checked the IGN E fuse and it's ok
SoCalMike
758
SoCal
Disconnect the mirror your have problems with and try the signal with out the mirror hooked up. If the turn signals work like it should then I would say it's the mirror you just hooked up.
contenderv07
68
ahh ok, I've give that a try. Thanks again!!
