LMM: Turn key, no power at all
VeeAte
going for 10s
Dec 7, 2010
177
ocean springs, ms
Well while i was working on building an egr delete pipe I made a mistake and did not disconnect the batteries. And sure enough the pipe arched on the alternator wire that i had disconnected from the alternator. Now when i turn the key to on or run position i am getting absolutely nothing..never seen anything like that before. I have no lights, the remote to unlock doors dont work, when i open the door i have no dome lights the whole thing is dead. I have checked every fuse in the box under the hood and the side panel inside the truck and they are all good. Checked the big fuses on the passenger side and am getting continuity on all of them. Any idea whats going on? The only thing I am left to believe it could be is the ecm
ugh, also the battieres are fine even tried jumping it off. Thanks for any help,
Mike<!-- google_ad_section_end -->
VeeAte
going for 10s
Dec 7, 2010
177
ocean springs, ms
Okay i will check them again, are there anymore hidden somewhere that i may not know about? Got the fuses under the hood, side of the dash, and then the fuseable links on the passenger side under the hood are all i know about.
