It's just like adding another turbo, the vortex spools the stock one faster!:rofl:
Can you elaborate on Vortex
I actually installed the Turbonator last weekend I like the results so far, less smoke, better mpg close to 2mph gained, and no the girl does not help with the install.
If the blonde comes with it I'm ordering ten. Looks like i could probably keep the blondes and give the part away as fruit choppers for christmas
You have to make sure it spins the air the right way. You don't want it going the opposite direction of the turbo or it will actually hurt performanceIt's just like adding another turbo, the vortex spools the stock one faster!:rofl:
There you go, trying to add real tech to a non technical thread... :angel:This is going to sound crazy but I think there could be some power to be had with a similiar device if used correctly.
If you blow smoke into a running turbo, you will see the air start to swirl before it gets to the charger. Spinning air moves slower, and is the reason most these "swirling" products have negative performance gains.
Jet engine designers know of this effect, so what do they do? They put in "stator" blades that don't spin. Think Turbonator. The stator directs the air into the spinning turbine straighter than it would normally be, thereby increasing the airflow.
But...
This effect is well documented, and I'm positive Garrett, BorgWarner, Holset, and the other turbo makers have tested it and found it to be ineffective.
Still, it makes me wonder if it would at least widen the map.
But...
So are you saying to put it in backwards to straighten out the air flow?
The stator blades are supposed to be airfoil shape, with an inclination towards the rotor blade. To complicate things further, the angle of attack increases at you go down near the tip. At least on a jet engine it does.
The "Turbinator" should be placed very close to the compressor wheel, as close as you can get, and it should have the same angle as the blade tips.
