Turbocharger Air Flow Spreadsheet
dmaxtruck
Perfect Sleeper
Jan 22, 2008
170
I'm confused, the spreadsheet says turbo air use, but the calcs look like you mean the maximum CFM that the engine can possibly use?:confused:
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
There is something wrong with this math. While it all makes math sense, we should be destroying turbochargers more than we are if it was true. I can take a GT4202R up to 140lb/min according to this sheet, yet the map goes up to 90. 50% off the map? Nope that can't be right.
Trippin
SoCal Diesel
Aug 10, 2006
663
According to my notes 1 cubic ft of air is .0807 lb at Standard Temperature and Pressure.
We are dealing with IAT above 60 degrees F. This is going to throw your calcs out of wack.
We should also be seeing VE in excess of 100% in order to make the power we do.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
I'm using VE as "cylinder filling". It is readily apparent that backpressure and charge restriction doesn't allow us to fully fill the cylinder with boosted air.
It shows up in our trucks stock at low boost levels.
So "VE" is a misomer. Guess it should be called something else.
Yes, it is most likely temperature causing it.
But I need some realistic temperature data to figure out what is up.
I still am struggling with collecting data off the truck, but it's entirely my fault this time.
Killerbee
Got Honey?
Since it's 460 I assume it's °F.
What are the other units and abbrev?
atm=baro=atmospheric pressure in psi. Most of us live around 14.0 psi. (14.5 near the coast) A few of us live at 12 psi (denver, etc)
460 is just converting to absolute temperature, F to R (Rankine). 100 F=560 R. Rankine must be used if wanting to use a density ratio correction for non-standard temperature, 77 F is standard T used by Garrett IIRC.
I use .073 for standard conditions. Guy and I have different numbers I guess. He's probably right.:hug:
