I'm having a problem, wait a minute I always have a problem, Anyway my truck is running poorly, lots of smoke no power, I've been reading some threads an ran across one where a guy had the similar problem with his an found the wastegate flap was broken inside the turbo, I'm only building 15psi at wot an it take awhile to so that, can u still build boost if the wastegate flap is broken an also could this be the problem????
I had a friend of my look at the log he thought it was a turbo issue also, any thoughts. I took my truck to GM ( yes those of u that knows me u read it right I give up) so I don't have it to check, but I can go in an check it in the morning.
