Turbo slow to spool up.
Red Dmax
Big Boy Toys
Apr 19, 2009
316
I have been working on my 04 LB7 for a couple of weeks now. I had to rebuild the transfer case and ever since I put it back in the turbo just is'nt quite right. It does'nt want to spool up and when it finally does it's building 3-4lbs less than it was before. I have checked for holes and leaks in all of my intercooler boots and tubes and have not found anything. Any help at all would be greatly appreciated.
Red Dmax
Big Boy Toys
Apr 19, 2009
316
It was running fine when I pulled it into the shop. I dont think it is a tuning issue but I could be wrong.
Red Dmax
Big Boy Toys
Apr 19, 2009
316
Bump. Somebodys got to have another idea on something to check. Me and maxaholic are stumped on what else to check.
fast03
1,201
61
Rancho Cucamonga
those boots and stuff can seem tight when they are not. really crank them down. No shop towels etc. anywhere in the system, egr stuck? wastegate not seating? clutch not holding? good luck
maxaholic
1,876
40
Central, Texas
The boots are on as tight as we could get them. The wastegate is opening and closing just fine. We don't know how to tell if the waste gate is not seating properly. And he doesn't have a EGR.
He told me the other day that it he eased into it, it would spool faster. So we have been thinking maybe to much fuel on the bottom and its choking out the turbo.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Have you tried the stock tune? If it works normal then you can start narrowing it down to tuning.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
as you stated try pulling some fuel down low and also pull timing between 1600 rpm and 2200 less timing down low really woke up my spooling .
Red Dmax
Big Boy Toys
Apr 19, 2009
316
Thanks guys. We are gonna put it back to stock this weekend and see what it does then I will definitly try cutting fuel and timing back down low. Sure appreciate the help. I will let yall know what happens.
dmaxvaz
wannabe puller
Nov 22, 2006
1,132
46
METRO DETROIT
thanks guys. We are gonna put it back to stock this weekend and see what it does then i will definitly try cutting fuel and timing back down low. Sure appreciate the help. I will let yall know what happens.
i had a slow spooling issue with my 01 and it was a dirty maf sensor. Clean it and see if that helps. i would do this before changing tunes just yet; especially if it ran okay before
