gonna go with an S400 or GT42 size? IIRC the Spruils took a GT4202 and a piss load of nitrous into the 9's
Not sure Nick. You know I love that damn spray, so I'm just researching ideas to see what will work best for me.
Nice run Matt... You guys have it dialed in or were you still working on shake down runs? I would put that turbo in a display case and mount it in the garage Good luck on your search for a turbo.
Thanks for the input guys. I really like that quick spool. If I decide to just wastegate a small turbo, do you think a true stocker is the most reliable??
You can always get a custom turbo tailored to your needs such as a small exhaust housing (for quicker spooling) and a slightly larger compressor housing and wheel. And heck if your spraying a bigger charger shouldn't be a problem cause from what I've seen you can spray and light it just as fast as a stock charger:thumb:. You can talk to a couple of vendors and i'm sure they can custom make you one.
TWINS WITH BOTTLE:thumb:
