Turbo Saying Goodbye?
millerman04
< The Man Cave
Jul 14, 2010
1,039
Clearville, Pa
For the past few months of running my truck, I've been hearing a weird air noise when I romp on the truck. Im not sure if its the turbo, or maybe an IC tube. It sounds like its on the drivers side of the truck. Its hard to describe the noise itself. Maybe someone on here knows what i'm trying to say. Thanks all!!!
12secondhandshaker
<---Stock trans
Jan 21, 2009
146
Sparta, MI
I have the same issue:mad:
I have removed and replaced boots lots of times and it still makes noise. i may remove my AFE boost tube and throw the stocker back on to see it it goes away.
millerman04
< The Man Cave
Jul 14, 2010
1,039
Clearville, Pa
Thank you!!! Someone out there has the same noise!! Its hard to describe isnt it? Thanks for a direction point tho guys!! Whenever the weather breaks from rain, I be checking that IC tube. I kinda thought that, but its not weak on the power climb. Thats what made me wonder.
DIESELMAFIAPER.LB7
<----new hotness
Jan 17, 2010
5,163
12
idaho
If its a small leak it probably wont hurt power much also do you Just here it while giving it some throttle or at all times
On edit: when did the noise appear? Was It after the pro Fab intake horn causeethey sound way different with those cause of the bleed ring being able to work right
9,906
152
Pressure test the whole works first. Could even be a hole in the IC!
DIESELMAFIAPER.LB7
<----new hotness
Jan 17, 2010
5,163
12
idaho
Well boost leaks I dont care what your running you will here a hiss, whine, whistle, ect...even at idle(at least that's been my experience) not just under throttle it will be alot louder under load an throttle so something else could be causeing this perhaps
millerman04
< The Man Cave
Jul 14, 2010
1,039
Clearville, Pa
Found the problem. My IC tube on the drivers side suffered from excessive rub from the ps line. I cleaned off the pipe last nite and felt it. yippy!!!! Time for aftermarket parts!!! :happy2:
12secondhandshaker
<---Stock trans
Jan 21, 2009
146
Sparta, MI
On my truck the noise is not existent at stock power levels.
The higher I turn it up the more the noise is made? I have to take the pipe off tonight and inspect clamps and the pipe.
millerman04
< The Man Cave
Jul 14, 2010
1,039
Clearville, Pa
The noise i have been hearing was even at stock power. It was just a faint air noise. Hopefully a new ic tube will help. Hope nothing else is wrong.
