The seal ring is very similar to a piston ring. When/if you rebuild it, pay attention to the compressor wheels orientation on the shaft. Best to mark it before you loosen the nut. That way you can line it back up when you're reassembling it and have the best chance of getting back to it's original balance spec. As for the piston rings, the small frame S400's are usually a one piston ring design on the shaft and the big frame is a dual piston ring. If it's a dual design, make sure the gaps on the rings don't line up and install them so they are at the uphill side of the turbo, you'll have less chance of leakage that way. I usually put them at 10 and 2 o'clock positions in relation to the oil feed.
Also, be aware of cheap chinese knockoff rebuild kits. Like anything, you get what you pay for.
