2002 LB7 all stock with 225K. The turbo is making a whining noise under load. If you let your foot off the throttle it will go away and then come back when you start to give it gas again. Seems to happen at higher speeds around 40 MPH or faster. At first I thought it was the fan belt but if only I was so lucky. Any idea's what could be the problem.
