Turbo issues on New Holland skidsteer
Combine Pilot
They Call Me Mike
Feb 7, 2010
647
Saskatchewan
I have a little issue with the turbo on our skidsteer. I had oil coming out the exhaust so i took the intake hose off the turbo and this fell out of the hose.
So then i pulled the turbo off to take a look at it and saw this.
So then i pulled the hose off from the turbo to the intake and found this coating the inside of the hose.
The hose had quite a few filings in it. They are all small and powdery and i don't see any big chunks out of the wheel. Will these small filings cause me any issues and should i be cleaning anything else out?
I know its not a Dmax but everyone here seems fairly knowledgeable about engines and turbos. :thumb:
Combine Pilot
They Call Me Mike
Feb 7, 2010
647
Saskatchewan
Thats what i thought as it is dumping lots of wet snow while i'm working in the shop. Long weekend here too so gotta wait for Tuesday to get a new turbo. :mad:
messejme
Jazzy, Me and Max
Mar 7, 2008
741
Branchburg NJ
All those particles went into the cylinders ughh! Some engines have a heat exchanger in the intake manifold assembly that should be cleaned out but the particle size on your finger means that most of the debris went into the engine. Warranty?
Combine Pilot
They Call Me Mike
Feb 7, 2010
647
Saskatchewan
No warranty. :damnit: I looked down in the intake manifold and i didn't see a whole bunch of filings, mostly oil. I'm just worried that those filings will score the cylinder walls.
messejme
Jazzy, Me and Max
Mar 7, 2008
741
Branchburg NJ
I would think the particle are an aluminum alloy which is soft compared to the rings and cylinder walls so scoring would be minimal or non existant from that but they could jam in the top ring land and force the ring into the cylinder wall by not allowing the ring to move freely in the land to compensate for thermal expansion. Unless you want to tear the engine apart fix the turbo and run it hoping for the best.
Combine Pilot
They Call Me Mike
Feb 7, 2010
647
Saskatchewan
It seems like its aluminum. I am going to get a new turbo, air filters and change the oil. I think i will run it for a day or two and then change the oil again. Sound logical?
RKTMech
Idiot with a wrench
Aug 18, 2008
936
The Norco's
Compression and leak down test will give you current state of rings, Bore scope to look inside cylinders another option. But clean the best you can and run it, if it starts to lay over then rebuild.
durallymax
Apr 26, 2008
2,756
Under The Hood
I think anything that wouldve happend has. Id say run it until it needs work.
What model skid?
Youre going to love the price tag those turbos carry.
Combine Pilot
They Call Me Mike
Feb 7, 2010
647
Saskatchewan
It's an 07 L175. We put a turbo on it a couple years ago cause the main shaft broke and now i can do it again. I think the last turbo was about $2000. :eek: Motor was redone two winters ago because someone (my dad) tipped it on its front with a snow bucket full of wet sticky snow and the engine was not getting oil while he was trying to get it tipped back on its wheels and spun a main bearing.:mad: Come to think of it that is why we changed the turbo too.
durallymax
Apr 26, 2008
2,756
Under The Hood
That series is terrible. We always had them in for engine issues. Had one with 22hrs get a complete rebuild.
I needed a turbo for our old Ls170. $1,800. Found one at worthignton for $400. Yet they wanted $150 foe the rear light bar. I said i could get a new one for $100. They checked and said okay $50.
The smaller they are the more they are. Just bought one for my jetta. $900.
messejme
Jazzy, Me and Max
Mar 7, 2008
741
Branchburg NJ
Even our duramax motors are half dark side(GM and Isuzu engineered). Go with the best built and engineered product is the most economical in the long run.
durallymax
Apr 26, 2008
2,756
Under The Hood
How is it half dark side? I meant Bobcat by dark side.
If you thought I meant japanese, NH used IHI Shibura engines. Our Cat's use Mitsubishi's and their D series bigger models use a Kubota.
Japanese engineering when it comes to small diesels is unsurpassed.
