turbo differences?
muhasamituffie
Dec 24, 2010
20
Thinking about buyin an Aurora 4000 turbo... its out of a cummins... i have an LBZ... is it possible to make that work fairly simply or would it require a wack of alterations? could a guy just get a pedastal to fit and good to go?
muhasamituffie
Dec 24, 2010
20
so probably best just buying the whole turbo and instal kit instead of just buying a turbo that i can find cheap and working around it.,.. counting all the hours spent trying to make some shit try to work
duramaxsandwich
Mar 30, 2009
206
its probably a t3 foot on the a4k, so get a t3 pedestal and you can make everything else yourself. oil feed and drain stuff you can get out of jegs. you will be paying probably double the cost if you buy a kit from someone vs doing the research and diy. biggest pain will be the downpipe
