Turbo brake, turbo life?
Swisstyphoon
258
Ft. Lauderdale FL/Switzerland
I was reading that some tuners offer a turbine brake included in their tow tunes.
They are using the variable turbo vanes to work as a brake help.
How does this affect the turbo life?
What are you thoughts about it?
Harbin_22
3,858
Southern Indiana
Mine has had a turbo brake for 50k and no issues. I can make 10#'s of boost decelerating. It really helps. When I had a cheetah, it worked even better and sounded good
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Back when I had a stock turbo I commanded 99% vane angle and made around 15psi with 0% throttle. Hold it in 4th gear at 3k rpm and let off the throttle, you will notice it :D
