so what tricks do you guys use to get the bolts out of the up pipes at the turbo ? 12 mm , ones , ? do them from the top or the bottom ? interested in hearing tips or tricks ?
I always go through the wheel well. Use a 12mm 12 point socket. Going through the well well you can get a breaker bar on them.
do I need to go from both fenders wells ? or only from the pass side ? and remove the pass side pipe completely ?
the oil suppy line ? leave or remove ? bolts under the turbo ??
Unbolt it from the engine and leave attached to turbo.
way easier to leave the supply line attached to the block, unbolt from the turbo and just use a bungy to hold the line back when you pull the turbo.
Wait what? How in the hell do you get the bolts in and out?
oil SUPPLY line buddy , not the return
