Turbo 400/Duramax?
13,716
779
Maybe I was told wrong, but I remember hearing that guys used to use those on Dodges, behind the Cummins, and had trouble with them breaking. Maybe those cases were rarer than I was led to believe or maybe they redesigned it. The main reason I bring up the 4L80 is because it is so similar to the TH400. I would think most of the things you do to a 400 would work on a 4L80. Maybe Mike could give a better answer. I could be way wrong on this. Also the 4L80 would be a smaller lighter package than a TH400/Gear Vendors OD combo.
15,681
I think the Duramax needs at least a lock up converter and probably an o/d to keep the rpm's in check.
15,681
4L80 will need hardened shafts and planet. I built the 4L85 in Diesel 5's Grand national with the Duramax. We bought a 4l85 brand new from the dealer because the Dmax van model had the hard gear train already and built it from there. Works pretty good.
mick
Try anything
Aug 15, 2006
482
Forestdale. Brisbane.Australia
So a 4L85 seems to be a better option than the 400 with od? How does it go with the high tq?
15,681
It's doing well in the GN which is running a tts extreme/moonshine EFI tunes. The car weighs 4600 lb. There is only one way to find out how it does in a 2500 HD with power.
15,681
Would I use the ATS Converter that I got with my Stage 4 from PPE?
No
I had to have Terry at PI build a custom one. I did all the measurements and fit for it and Terry built it. I'm sure ATS can do the same as could Suncoast.
Ben46a
Wannabe puller
Sep 4, 2006
275
41
Waverley, NS, Canada
I was asked to post here by a member on the DP because i have an LLY motor bolted to a TH400. But i dont have a heck of a lot to say about it really, just wanted to see if id run into problems. Flexplate should be minor, just drill some holes, I have a ford NP205 bolted to it with chevy input and dodge 32 spline shafts and thats it. Its not running, not in a truck, and will probably never come to fruition.
15,681
Drilling some new holes in your flexplate could be disasterous. It will be out of ballance. Nobody said you could not do it; that's easy. Is it going to be worth a shit once it is done? I don't think so.
duramaxin14
Just Keeping Up
May 25, 2007
912
Wauchula fl
Not to still the thread here. But mike quick question. Will any other bellhousing wrap around the ally. Other then a ally bellhousing and still match the bolt pattern on the motor. I need a new bellhousing and was wondering
13,716
779
Lots of bellhousings will bolt to the motor, but not too many will bolt to the Ally.
