After lots of searching, I only came up with a couple things. If you don't want to run a MAF you just max the tables and change it to not reported then you more or less have to drive it with your right foot to control spool/smoke? Anything else I should know that might be detrimental? MPG losses? Driveablity issues? Basically I screwed up. I don't have a MAF sensor lying around and I forgot to put a provision in my intake tubes before paint. Before I grind off paint and build a plate for a MAF I figured I'd ask if it's really even necessary, if I can "drive around it."
