Tuning with a Aftermarket Radio??
Dec 2, 2006
1,696
TN
I just put in a aftermarket radio in my truck. I've heard this gives a greater chance of stalling things or "frying" things when flashing?
Don't want to be stuck with a dead truck...:D Thanks
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
Some people have problems with them some don't :D Pat has never had a problem flashing Wendy.
Cougar281
1,827
264
St Louis, MO
I think a big part of that is whether or not it ties into the Class2 bus. If it doesn't (which I'd GUESS that none of the aftermarket headunits do), then you'll be fine. If you have something like an iPod adapter or the Sirius adapter or other adapter that ties into the radio on the class2 bus along side or in place of the XM reciever, than you could have problems. If you're concerned about the HU, pull the radio fuse when you're going to flash. With all stock "stuff" on the Class2 bus, I've never pulled a fuse, and knock on wood, I've never had an issue.
And to add, I see that you have an 06. With an 06, I'd say you have near zero chance of anything causing any issues, unless you have a huge amp that drains the batteries powered on when you're flashing. Since the 06 flashes on the GMLAN bus, and AFAIK, there are no aftermarket devices that tie into the GMLAN bus (The only thing it's used for in the 2006 LLY, and 2006 & 2007 LBZ is the ECM, TCM & GPCM with leads coming back to the DLC for programming and diagnostics), I sincerely doubt you'll have any issues.
Dec 2, 2006
1,696
TN
I see where your coming from. I guess this would be included into the class2 stream, seeing that my PAC adapter runs though the Onstar and bose speakers?
So, when you do toast a ECM, is it actually toast, as in throw in the trash, or can somebody reprogram to make use again?
Cougar281
1,827
264
St Louis, MO
Yes, the PAC adapter could cause issues in an 01-05. As I said in my post (in my edit that I completed after you started replying :eek:), since you're flashing on the GMLAN bus, and the PAC is on the Class2 bus, I doubt you'll have any issues.
LarryJewell
Back with his honey :)
Jan 21, 2007
10,152
58
San Angelo
I cant flash without pulling the radio fuse :(, I got tired of pulling the fuse so I installed a switch to kill the fuse rather than having to pul it everytime:D
Cougar is right. The LBZ flashing communications occur on the GMLAN bus - most aftermarket devices don't communicate on GMLAN but on Class2. Effectively this should remove any nerves you have about flashing your ECM. The other advantage that GMLAN has over Class2 is that it is more stable when it comes to being interupted during programming.
Cheers
Cindy
slowlmm
Mar 2, 2008
2,582
46
so cal
I have never had issue with mine with efi. knock on wood :) I did have issues when i had a ppe tuner thoe for wht ever reason.
