Tuning question for an lb7
03pewterdirtymax
ex ford guy
Oct 16, 2011
Hey fellas new to the duramax. Gotta question... Just ordered a ppe standard tune, intake and straight pipe what kinda power will I see? What are guys running in the 1/4 with this set up? Any help is most appreciated as always!
nuffsaid
74
Worland, Wyoming
Depending on the health of your tranny, level 3 or 4 will be all your tranny will hold without limping. In my wifes 01, level 5 will limp the tranny every time on 4-5 shift after smoking tires through 1-2-3
Level 4 has limped the tranny a couple of times but is typically a good tune.
A transgo shift kit and converter will help you hold the power very well.
GeneralTJI
Turbo Todd
Jun 1, 2010
1,272
Colorado
14's in the 1/4 if you have tie-rod sleeves and launch in 4x4 (assuming you have a 4x4)... if you don't have the sleeves don't bother running it. If your truck is 4x2, get good tires or don't bother running it
The PPE is rated as follows (at the crank) subtrack around 20% or so of that for a rwhp estimate
LVL.....HP.....TQ
1...... 40..... 97
2...... 90..... 160
3...... 120.... 200
4...... 160.... 240
5...... 225.... 335
All just estimates, trap speed and weight will give you a real hp number.
Be careful above lvl 3 on the stock 5 speed
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
People been known to run low 14s. With a good tuner, or efilive. And bolt ons. Tierod sleeves and lower your torsion bars and you should be able to net atleast a 1.8 60ft putting u into sub 14s. I know way back when, when I had my 06 lly with a quad stealth 2 tuner on a 70 hp tune in 2wd I ran a 14.5.
