LB7: tuning help
ZeroGravity58
1,401
51
Maryland
I need some help with my tune. Im lost and im not the best anyway. I dont have alot of cash but can give someone a few bucks to help me out. Im running a old tune that i scripted over from my 01 reg cab to my 01 crew cab. For some reason at WOT my rail pressure is falling to 12-13K and the main injection on time is 3800-4000us :confused: Can someone give me a hand? I have a few logs also but dont know how to post them. PM me and i will send you the logs/tune or give me things to check please...Thank you!
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
Id back that pulse down alot. Try backing it down to 3000us for a max and see how it goes. You can send me the tune and I can adjust things for you if you'd like also. [email protected]
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
Well then Id use the stock tune that came with the truck and go through it manually instead of scripting it and see if that works for you.
ZeroGravity58
1,401
51
Maryland
never mind. I uploaded the PPE350 tune i had and it hold around 16K. If i command 160MPA at idle it will only hold 16K so i dont know if it is a CP3, injector, or the FPRV. All my balance rates are +-2 at idle and +-3 in drive.
ZeroGravity58
1,401
51
Maryland
i hope. Im going to check the FPRV. It holds rail pressure fine up to 100 MPA then it wont hold any higher. My lift pump holds 6 PSI at WOT still.
