After the twin install i needed to get rid of my coolant and MAF dtc's turned them to non reported and am still getting low coolant light. any help?
Kelly
Kelly
YOu can tturn the light off?
There is actually a sensor in the expansion tank. You can fool it by completing the circuit or a zip tie (IIRC). Why is it saying low coolant? are you using a differnt expansion tank???
Using a different tank.
not sure, if full voltage shows full and low voltage shows empty then jumping with plain wire will work. if opposite it may need minimal voltage to show that the sensor has not fried or not been plugged in.
