wiring i've done
installed tts pumps and they are working
tapped into following wires
-boost sender wire(light green
-oil sender wire(white/tan)
-ignition wire(pink)
-hot terminal
-ground
tapped in two other wires but taped them back up good(light green)once i realized they were the wrong ones, now these wires are all right there beside the fuse box under hood comin from the two big plugs where you would plug in an edge tuner. what gets me is usually when you undo stuff and tape everything up it goes back to normal operation i did that before i proceeded with the install and no change. what i am thinking is somewhere there was a loose connection and when i was in there moving wires around it started not neccessary the wires i was working with, but what plugs/wires are there tied into the brakes in that area i guess thats the big question, again the pumps are now working properly -the two turn signal arrows in mirrors come on faint when brakes applied along with the dash turn arrows,signal lights quit working when brake applied, kind of like when hazards are on and you apply the brakes i guess that about sums it up if you need more let me know!!!!
thanks!
