TTS head studs
messejme
Jazzy, Me and Max
Mar 7, 2008
741
Branchburg NJ
I was told by ARP that they make 2 different Head stud kits for the max. The "2000" set that sells for between $500.00 and $700.00. The "custom age +625" set for around $2000.00(Obviously the cheaper set stretches, hence they made a better grade).
Then there is the TTS set that sells for around $1200-$1300.Huckstorf diesel had a nice write up about all three.They had good things to say about the TTS set.
paint94979
Beer Nazi
Sep 18, 2006
11,715
Honestly I would go with ARP studs hands down. The R&R that ARP has put into there design can't be touched by TTS. The ARP 625 studs can be had for a lot less than 2000$.
9,906
152
So I understand this, TTS and ATS sell studs that are of a strength that is between the cheap and expensive ARP studs?
SBCNX20
Junior Member
Aug 7, 2006
354
53
Central MA
Summit has em
Product Line/Description Price Range
Sort By: Product Line (a-z) Product Line (z-a) Default Sort
ARP Pro Series Cylinder Head Stud Kits
Head studs for the pro in you.
These Pro series studs from ARP are cold-forged to ensure molecular integrity. They are heat-treated prior to thread rolling and machining and are rated at a whopping 190,000 psi. The Pro series kits are also available with 12-point nuts, and all kits come complete with hardened parallel washers for...
$659.95 - $659.95
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
SBCNX20 - that is for the ARP studs part # 230-4201 which can be had from many vendors here (including us) for $650. The more expensive ones being refered to are part # 230-4202 which can be bought from Jegs for $1504.99.
Mika
Bastardo Finlandias
Oct 25, 2008
291
Finland
What is recomended TQ spec on those studs? Is it more than normal ARPS
It was 140 ft lb, and same again after 1 day standing iirc.
For me it have been working very good so far.
Standard ARP studs lift heads with milder turbos and tunes in same km´s.
