Truck won't start
crazycrew
Let's Start A Riot
Oct 3, 2009
1,230
S. Louisiana
Started it this AM to warm up before bringing the kids to school. Got in in cranked and put her in R to go to the carport. When I shifted into drive to pull up, it stumbled real bad. Almost killed. Didn't pay much attention to it for some reason.
Parked it in the carport and the hi idle kicked on. Brought the kids to school and it ran fine.
Went to leave for work this evening, she started, ran for 5-10 seconds and killed. Would not restart.
I will change the fuel filter when I get home in the AM.
I'm also gonna hook EFI so I can check fuel pressure.
Any other thoughts or suggestions. This is the first time i've had any kind of problem in the last 1.5 years I've owned it!!
dearthr
Mobile Chernobyl
Apr 12, 2010
20
Is it at least cranking over? Make sure it is primed, and check the valley area for fuel...it might be sucking air in between the filter and the fuel rails or pushing fuel out. Good luck!
crazycrew
Let's Start A Riot
Oct 3, 2009
1,230
S. Louisiana
It had a few codes Brian. I actually didn't write any of them down, I was trying to leave for work, so I cleared them to see if it would start. No go! I do remember 1 of them being a B1003 or something like that.
Dearthr, yes, it does turn over. I will check prime when I get home.
I actually didn't have time to check much, I was running a little late for work as it was
