truck wont move
liv2dmax
Oct 23, 2012
Just got the stage 5 ppe kit installed and topped it off the tranny took about 20 quarts of fluid and started up like always with no noise or anything but i go to put it in gear and nothing happens. Any ideas?
jc1843
Sep 27, 2009
228
86
So Calf
Pull the pressure plug -- close to the filter-- start engine and see if pressure oil comes out-! If not, you may have the pump gasket on wrong-!
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
Nope!
What year truck ? Call Dan he'll fix you up or broker a deal to get you fixed up! :roflmao:
liv2dmax
Oct 23, 2012
I took that plug out and started it and fluid came out and had some pressure behind it. It has no codes at all.... how can i tell if the shift linkage isnt hooked up right? its a 2004.5 lly... and how do i get ahold of dan
catman3126
Ehhh?.... You don't say?
Jul 24, 2012
2,636
NE Oregon
Mike L told me when I built mine to never put one in reverse after a build. If memory serves me right it was the E shift valve that can stick and cause a no move issue if there was any debris in the trans it can make this one stick, might pull the valve body apart and see if anything is sticking.
chevyburnout1
Fixing it till it breaks
Aug 25, 2008
2,368
Berthoud, CO
That happened on my first build but the truck still moved. Was just in limp mode.
liv2dmax
Oct 23, 2012
ok so i got the truck to move but it will not move in reverse at all. i can pull the round connector and it sends it into limp mode and it will move in reverse. Also it moves in forward but it doesnt move worth anything it just revs up and i can get to about 10 mph.
liv2dmax
Oct 23, 2012
If I unplugged the round connector at the back of the engine and it works in 3rd and reverse would that sound like the nsbu???
