Truck takes forever to warm up
Mdmax
Aug 30, 2009
29
So I just put in 2 new Oem stats, coolant is testing good. What am I missing. The other day it was around 40 degrees, I started the truck and I got distracted and it idled for at least 15 minutes, when I got in the truck the needle barely moved, it took another 10 min of driving for it to come up to temp. I don’t remember my last lly taking this long
ZeroGravity58
1,401
51
Maryland
I can start mine up and let it idle for 10 min and get in and have some heat but the needle won't move. It hasn't been very warm here so they are going to take alittle to warm up...
3,726
296
Sounds like my stock LB7. You basically have to drive to get heat. And my built LB7 will actually cool down if you're not driving. It can be up to temp, but 10 minutes of idling in 15°F weather and it'll drop off the gauge.
I think that's why GM went to all the work to do the high idle stuff where it loads up on the torque converter in the later year. Only way to get heat without moving.
Sent from my Cat S60 using Tapatalk
Dozerboy
4,892
470
TX of course
Even my LBZ doesn’t heat up that good. High idle fine, but without it you’re lucky if it’ll defrost the windows in 10 minutes.
5,805
use to let my lb7 idle in single or teen degree weather for 30 min before work. it would barely be blowing some heat by the time i get in it. moved to warmer climate and i dont have this issue anymore :roflmao:
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
going to work in single digit weather if i let off the throttle and decelerated it would start cooling down. said **** it and moved to warmer weather also :D
now i have to run low temp stats and it still wants to get too hot in freeway stop and go... you never win :roflmao:
2,135
My LB7 took about 10 miles of driving before it had any significant heat. And like mentioned above, would actually start to cool off if I started idling too much
5,805
you could do like my buddies with company trucks do. 2nd or 3rd gear, wot, rev limiter bangin and you get heat REALLY fast
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,492
472
Central OH
Let mine idle long enough to scrape ice off if there is any, then just drive it. Screw waiting on heat, that's what seat heaters and gloves are for
2,135
Or power brake it :D
That should put a little heat in the transmission which in turn will help heat the coolant
3,726
296
Yep, I have become addicted to heated seats. Makes me wonder if heated steering wheels are just as nice?
I can't bring myself to do that to my truck or Suburban, but in my Pontiac, I start it and GO. When you pay $2k for a car (and can easily get more for the same), suddenly the guilt of hammering a cold engine goes away. And boy do you get heat quicker that way :woott:
BlkMax
743
Wasilla, AK
It has all been said previously. My LB7's NEVER warmed up (and produced heat) without the high idle and the winter front on both the bumper and grill.
Mdmax
Aug 30, 2009
29
Ok I guess this is normal then, maybe I’m over thinking it, like I do with everything
