truck smokes at idel
tomc983
tomc983
Jan 20, 2009
154
New Jersey
i just notice today that after i got home from work my truck was smoking a little not to much but a noticable amount. is this normal im used to my old 350 smokin whan leeting it cool down but not this truck. should i be concerned?
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
whats the status of your pcv and egr? pop off the boot coming off the turbo and have a look for excessive oil.
dmaxfireman
Apr 8, 2007
2,329
CT
check your balance rates asap and open the oil fill and smell for diesel, your injectors may be on the way out. if they are get them warrantied before they burn a hole in your pistons or fill your crankcase full of fuel.
S Phinney
4,008
Quncy, Fl
That is a number referencing if the injectors are working equally. It is veiwed while at hot idle in gear with a/c on etc. With engine loaded at idle. If less than a 4 to 5 number difference they would be ok.
