Truck randomly loses power
Porno Joe
513
South of Pittsburgh
I ran out to grab lunch at work, stopped and filled up with diesel too. i left the station and truck was running fine. I drove maybe a mile, and pulled out of an intersection and when accellerating up to about 40 or so, the truck lurched at the 4th gear shift. caught me totally by surprise so i had no idea.
it continued to do this intermitiently for about 1/2 a mile. what i did learn was that my rail psi gauge was dropping to 0 when this happened. I was able to watch my rail psi as i was coasting down a small hill- foot off the accelerator, it was holding steady at 5-6k. it randomly drops to 0 and then bounces around for a few seconds. it would do this about every 2-3 seconds for roughly 1/2-3/4 mile and then poof gone.
I drove the other ~5 miles back to work, taking it easy, without issue. I was really easy on the truck, but did push rail pressure up to 20k once and no issues.
Any ideas where to start looking?
Truck has dual cp3s- orginal in valley with a new reg. 2nd cp3 and reg all new in fall of 2012- maybe 10k miles since then
Air dog 200 is running.
and i am 100% certain i filled up with diesel.
Duramax One
Vote for Pedro
Aug 11, 2012
140
Oroville, CA
To me it sounds like you might be having wiring issues with your dual CP3 controller. If it is randomly losing power/signal or has an intermittent connection to your FPRs you could see issues like these.
Porno Joe
513
South of Pittsburgh
Thats kinda my thought too. just odd that i havent touched anything related to the cp3 wiring in awhile, and this randomly started
MaxPowerLB7
Amateur
Nov 8, 2007
623
Spanish Fork, UT
I you lost power then the regulator would default open causing high pressure. I would guess its pulling in air through a cracked hose/fitting before the lift pump.
Dmax87
171
Ever thought maybe bad batch of fuel? Very well could be a wiring/fpr issue but kinda weird it never had an issue until you got fuel. Maybe new fuel filters and a good additive. Worth a shot
Porno Joe
513
South of Pittsburgh
has optilube in the tank.
I filled a 5 gallon jug at the time i filled the truck, So i will pull some of out the jug and see what it looks like.
I agree its very odd, esp because i have driven the truck since putting the van hose on. prolly 30 miles in total with no issue, and then this randomly happens.
leaving work in a few, will see what its like on the way home.
Porno Joe
513
South of Pittsburgh
well I cannot get the truck to repeat this.
Friday after work i pulled fuel out of the 5 gallon jug, and drained my water separator. no issues with the fuel its clean as could be.
Drove the truck about 60 miles on saturday. no issues, even did a few quick full throttle pulls at 25k rail and no issues.
