Help: Truck keeps dying.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
For the past 2 days my truck just dies when I let off the throttle sometimes. Voltage looks okay, rail pressure goes to around 1000, sputters and slowly dies. Tonight I got the messege battery not charging on the DIC while it happened. Could my alternator just be dead? I'm not sure because it still says I have 14 volts when this happeneds..
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Might be a cp3 regulator or the cp3 itself? I have 12 psi from my lift pump. I will check grounds tomorrow, and maybe test my alternator at autozone.
seth999
Wheeewwwww!!!
Jul 1, 2009
439
Corbin,KY
I'll be in Lexington Monday if you want me to fix it...:D...I would try the alternator and have batteries load tested
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
Mine kept dieing and the water seperator was full and not letting fuel flow.Just something easy to check i guess.Could your lift pump be stoping or locking and the motor dies? Good luck and keep us informed please!!!:thumb:
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Tested the alternator it checked out fine. Only dies when I let of the throttle and about 50% of the time that I come to a stop. I'm putting the stock tune back in it now to see if that helps. DVT function the actuall follows commanded up to 160 but I relize idle isn't much of a load on the cp3.. Anyone ever have a cp3 fail like this? Its almost like the dead pedal you get on the VP44
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
My lift pump is working. I think it may be something I did in the tune, didn't happen on the stock tune, but only went for a quick drive. Put the older tune I was running on it just now and it worked fine until about 15 minutes of driving pulling up my street it wanted to die again.
blk smoke lb7
Nov 8, 2010
5,694
57
belvidere,ill
What about a faulty tps?The foot pedal tps? The tps in the wifes car didnt set a code when it went bad and the car kept dieing on her on the way to work I changed it in the parking lot at her work and all is good.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
I thought about that too, I've had some weird throttle issues in the past like a dead pedal for almost 10 seconds before it took off. But its commanding the rail pressure when it happens, just doesn't follow it... So IDK if its a cp3 problem or what. I did see that number 5 injector has a balance rate of 6 or 7 at idle, could just be the problem?
blk smoke lb7
Nov 8, 2010
5,694
57
belvidere,ill
These trucks and the electronis do some really weird stuff look at the noise my truck and ha26 is making and nobody has a clue im in the same boat:confused:
messejme
Jazzy, Me and Max
Mar 7, 2008
741
Branchburg NJ
I noticed that my battery voltage was too high, I am having the same problem, stalling after engine is warmed up and a short drive. I think the ECM/ FICM is getting to much voltage.
