Truck is having a hard time turning over
GregorySalatino
Mar 2, 2015
5
I have a stock 08. I noticed the truck slowly having a harder time turning over. It seems like it cranks just as good as it always has, it just seems to keep taking a little longer to turn over. Any ideas what this can be?
melms23
253
WI
Check your battery connections first. I had a loose ground and had a similar problem.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
"turning over" and "cranking" are the exact same thing.
Im not sure what you mean by "it cranks fine but its having a hard time turning over". That makes no sense? :confused:
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Is it turning over slower, or is it turning over longer before it fires off? I know some trucks pop right off while others take a few seconds. Mine is one that takes about 2 seconds of cranking to pop off. Has always been this way except for when I had bad injectors(it actually cranked nearly instantly with bad injectors).
Awenta
4,090
CT
I agree. With a bad battery mine cranked slower but still fired within a couple seconds. New battery it cranks fast but still takes a couple seconds to start.
ironmax
chock full of goodies
Jul 7, 2010
502
27
Col. Ohio
Start with easy stuff first. Log rail pressure if possible. Change fuel filter. Check for fuel leaks
