Today my truck started feeling like it is popping out of gear in reverse. It feels like it's in neutral for a second then bangs back into reverse. It only does it some times when you are backing up an incline or a trailer where you need to give it some throttle to keep moving. I cannot get it to happen by holding the brake and giving throttle stationary It seems the truck needs to be moving. Seems to do it 50% of the time. Otherwise it is normal with no noises when it's not acting up. Can the transfer case cause this sympton only in reverse? I'm hoping it's not in the trans. Trans was built almost 3 years ago and has been flawless. I'm going to drain the transfer case fluid when I get time and check for metal but wanted to see if anyone had this issues and could point me in the right direction.
Thanks
Thanks
