Any ideas if your injectors can take a dump and balance rates be good? It drives completely normal, just puffs a soot cloud at start up and hazes at idle like I mentioned.
My Dad's '02 has been doing the same thing
Balance rates are within spec...
Here are the results...all was done with a Tech II...
Desired Rail Pressure 160.0 MPa...Actual 150.9 MPa = Failed
Balance Rates *in Drive
1...-1.3 mm3
3...0.8
5...0.1
7...-1.0
2...-0.0 mm3
4...2.8
6...0.5
8...-1.6
