Truck getting slower
Vasbinder
282
Floresville, Texas
I changed tires size from 315-75-16 to 305-70-16 same tire brand. I used the Edge's 1/4 mile timer and the truck runs in the 16's it used to run in the low 15's with the bigger tires. I cleaned the Air filter and changed the fuel filter. It had bad fuel in it I drained it cleaned the tank and flushed the fuel lines. Can there be something else plugged up past the filter. The return line at the tank looked dark and rusty color like what I cleaned out of the main line.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
If you have bad fuel in the return line and rust you could of damaged the regulator / cp3 / injectors/ return fuel lines under the valve cover
Big Block 88
Multiple choice muscle
Nov 3, 2008
4,665
Kansas when I am home
Are you basing your slower performance purly off of the edge unit?? If so those are not the most accurate calculations in the world. Or is there somthing else leading you to beleive the perfpormance is down
Vasbinder
282
Floresville, Texas
Yes off the Edge. To me the smaller tires should run better I can't smoke them like the 315's even on slick black top. Even on top end it dies off. But it still beat a new Tundra
