So my old girl (the truck lol) gave the wife and i a little scare this weekend.
Headed up north for the weekend with a full load on the back (5th wheel loaded with the tracker). pulling the hills i had no issues other than her getting warm up the hills. Soon as we finished the last hill, i had a good 2 mile 6% down hill on a 2 lane road. i was running 55mph which was the speed limit and would slow for corners. truck was doing its down grade shifting and was in 3rd gear at 3400rpm as we decended. Still needed some brake even at that rpm.
not a 1/4 mile into the down grade, abs/ebrake light flash, then flash again and gauges go nuts. Truck starts rattling and blowing white smoke so i throw it in N and turn the truck off all while still doing 55mph down hill. go to restart and i get nothing. so i start trying to alternate braking between the trailer and the truck. by the time we got to the bottom of the hill i was using all the brake i had in trailer and truck to get slowed to a stop and pull over. there was no coming to a stop coming down that hill. luckily i could get her slowed to about 40-45mph down hill and keep it there without riding things too hard initially.
So we get pulled off and i go to start it again. hit the key to start and nothing, not a sound. leave the key on run and all the gauges work, lights work, nothing shows being amiss. So i check all fuses inside and out with a test light and nothing is blown. find one bail connector is loose so i pull it, check pins and all looks good best i can tell. plug it back in and still no start. i would be throwing my efi live on it by now to check for codes but i left the damn thing at home (i never do this either, not happy at this point). so i pull the battery negative and unplug the trailer plug. leave it off for 30 sec and replug it all in. No start still. Now when i unplugged the batter, the glow plug controller started making some interesting buzzing noises. but once i unplugged the trailer from the truck, it stopped (obviously). Now i dont have any glow plugs in the truck and the wires for each glow plug are cut flush to the harness from when brian had the harness for his race truck. So no wires are touching anything. i unplugged the main power wire to the GPCM and try to start again. She fired right up! so i think the GPCM is screwing with the truck some how. the truck also turns over much easier and quicker now
We get all set back up and head on down the road. initially i had a ABS light when i first left but it shut off soon as i got to 15mph. figured it was from pulling the battery cable. we get about 10 min from camp and i loose converter lock up in 5th. still shifts fine but there is no lock up in 5th. so i down shift to 4th, same deal. i slowed to 45mph and it locked back up and stayed that way till we pulled off for camp. thought that was strange.
now we leave to go back home and all seems to be good. again, ABS light back on after start up till i hit 15mph so i figure i have a hurt wheel speed sensor from my major braking or a wheel bearing dieing. we come to a long 9 mile 6% grade with winding 2 lane. again, down grade shift to 3rd gear and am up to 3500-3600rpm. all is great till i come to a lull where i im running about 52mph in 4th gear under some throttle. i click the tow/haul button to let the truck up shift to 5th and as soon as i click it, same shit starts to happen again but i immediately hit the tow haul button again and it stops doing it and runs fine. never did it again on the way home or the rest of the way down the hill.
its a hell of a long shot but anyone had this happen before? its got to be electrical whether i have a hurt TCM/ECM or something else? there are no burnt wires, no cut ones. checked the normal LLY wear through spots and nothing i can see. definitley not the "ice pick" issue has ive had that happen and its no where near this dramatic. i posting this with me not having much diag done on the truck yet so i know im missing some info that might help.
