LBZ: Truck cut out, stopped pulling
JD4440
<< Lo-Carb Monster
Feb 27, 2009
1,776
Orlinda, TN
[YOUTUBE]1k5vo5qqVms[/YOUTUBE]
I have no idea what happened here. Pulled in high lock/ 1st gear lockout, 8350lbs, it always does good but the track was harder than I anticipated. I made it only a few feet (10-20) and it felt like I let off the pedal easy and got right back into it. At the end it always spins even with 1500lbs on the front, this time it felt like it was still pulling/spinning but obviously it wasn't.
No trouble codes at least none the CTS could see and I didn't get a log because the DLC is used by the monitor :mad::mad::mad: Truck drives normal now, maybe Torque Management :confused:
:witch: fixed link
JD4440
<< Lo-Carb Monster
Feb 27, 2009
1,776
Orlinda, TN
some 1/3 tread BFG's 55 in the rear/ 30 in the front. T/H was on but not sure how much that matters in 1st
JD4440
<< Lo-Carb Monster
Feb 27, 2009
1,776
Orlinda, TN
I'm not hitting the rev limiter it just feels like it gets to a point it just doesn't pull as hard, like it's out of the powerband.
