Allison 5sp: trim vavles sticking
skintback
Take this one to church
Mar 5, 2007
919
Florida
I have a valve body here that the trim valves are not sliding/sticking is there a reamer tool for that everything else is good in the pump and the rest of the valve body
Thanks Sonny
15,681
It is very rare to see trim valves sticking unless there is a lot of grit in the valvebody from damage or the trim valves were forced in the bore. I like to use cutting fluid and work the valves in their own bore up and down. What ever you do, do not sand the valves.
skintback
Mar 5, 2007
919
Florida
Valves look ok i'll give those options a try thanks
Yes the trans was in pretty bad shape c1's were melted and c3's smoked
