OK, I was working on the trim valve part of the transgo kit last night. First question, how do you get the inner valves out from the valve body? I tried a magnet but they would not come out that way. Do you lay the valve body on its side and try and shake them out?
The "B" trim valve has no spring on the outermost part like the "A" trim right? (just after the solenoid?)
What if I was stupid and took an alan wrench to the little needle set right on the end of the solenoid (behind where your wires would plug in) and took it out? I THINK I got it set right where it was before I took it out but I'm not sure? Please dont ask why I took it out.....
OK, I took it out because the screen on my "A" trim soleniod was/is full of clutch material and some metal shavings. I thought maybe I could blow air back through there but once I took it out I decided that might not be a good idea....... so how do I go about getting the crap outa the screen? Whats funny is the "B" solenoid screen had nothing in it?
So, after the book, my main questions are:
1: How do you get the actual trim valves and springs out of the VB?
2: How bad did I mess up the "A" trim valve messin with that screw and how do I get the shavings out of the screen?
