Allison 5sp: Transmission help!!
nshadday
Jan 13, 2012
42
Anacortes, WA
Hello Everyone, I have a 2001 GMC 2500HD Duramax LB7. I have an issue I would love some guidance on. When using my EDGE CTS Tuner in TOW mode. The transmission will pop out of 5th gear and the engine will redline for a second or two. Then it will lock into 4th gear and will not return to 5th gear unless I pull over and clear the codes. This happens when I'm pulling my 9klb toy hauler up a steep hill. Addtionally, If i place the tuner in "performance" mode it will do the exact same thing if I'm already at highway speed and i attempt to accelerate quickly. I have reflashed the programmer and even downloaded the lastest updates. This has been going on now for about 6months.
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
P0700 is just saying there is a problem. Should have been other codes in the TCM associated with the issue?
5,785
im hearing "limp city". if thats the case, you dropping to 3rd gear, not 4th and bascially your trans is dieing fast
nshadday
Jan 13, 2012
42
Anacortes, WA
TO be honest I dont remember seeing any other codes. I'm currrently deployed overseas so i can't look into it further right now. With the information I've provided. Are there any ideas? I have a mechanical buddy who mentioned the possibility that the tuner creates to much power for the transmisison which causes the transmission to go into a "safe" mode? I'm not sure if that is even possible. Just looking for help
5,785
without actual TCM codes, all we are doing is guessing. get us those and then it can be determind what needs to be done
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
Its obvious the trans is going into limp mode from too much power...
I highly doubt there is anything wrong with the trans other than it can't handle the power that high.
I would bet the code is for 5th gear incorrect ratio.
