Transmission going into limp mode
jzts0214
Nov 29, 2010
109
Strasburg CO
Hey Mike I have a tranny problem. First time truck was downshifting from 2nd to first and it felt like the trailer brakes locked up. Turned the truck off worked fine for 2 weeks 25 mile trips. Next time I drove it 50 miles samething in the same spot. Truck was down shifting from 2nd to first. Feels like the trailer breaks lock up. This time shut it off. Take off and within 3 blocks same thing. Limped it home. Took it to the local shop solenoid b shorted and p0776. The fluid looked clean but metallic colors. They change solenoid b now on the test drive they say when it shifts into 4th it goes into limp. The tranny had 50000 miles on it since it was rebuilt with a sun coast. Mainly running about 500 horse tow tune pulling trailers but don't run the piss out of it.
15,681
P0776 is NOT a shorted out solenoid. It is a tie up ( 2 gears at once for a second ). Who built it and how was the trans used?
jzts0214
Nov 29, 2010
109
Strasburg CO
Detroit transmission in Denver built it. I'm sorry I should have been clearer. It had a lot of fault codes to start. Then they cleared them drove it. Got the solenoid b shorted error and I'm pretty sure a p0776. They said the valve body was contaminated
