I changed the tranny cooler, replaced factory lines with fleece lines, and changed spin on in pan filter. Due to receiving the incorrect in pan filter twice, I had the fluid draining for almost 5 days. I was able to capture 12 quarts and probably another 2 quarts on the garage floor. I finally received the correct filter and put everything back together. I added 12 quarts of fluid and nothing is showing on the dip stick. I then added another 2 quarts before I could get it to register on the dip stick. I have continued to add fluid in half quart increments, I am now up to 15 and a half quarts and this is where is it showing on the dip stick. (see below pic) Here is my question... with the trucks transmission temp at 140 degrees this is what the dip stick shows. Should I be reading where the dipstick is fully covered in fluid or as shown in the pic where the fluid is to the hot full mark. My concern is that is not fully covered in fluid, I have checked and rechecked about 20 times and its staying the same. I am probably over thinking this but I cant afford to mess this transmission up because of a fluid level. Any help or suggestions would be greatly appreciated!
