Allison 6sp: TransGo Jr. installed now giving me P0972 code
ruffmanatv
Yeah, its got a D-Max!
May 9, 2008
3,640
46
Van Wert, OH
Talked to Mike today and he said it was a wire not connected, but I just had the pan off and check all the wires Twice. Silinodes are all in the correct locations. Code throws trans into 3 gear and will not let it shift from there. Any Ideas? In need of desperate help. :(:confused:
beach_33
704
des moines, IA
check and make sure that the main harness is plugged in all the way. as well as glance at the wires on the inside of the pan from the plug. i would disconnect the plug and make sure none of the pins are bent or covered in dirt or something
gmduramax
Shits broke
Jun 12, 2008
4,081
252
Nor cal
not sure if this will help but I know a guy who didnt fill the fluid up all the way in it was setting codes
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
go back and double check all harnesses like everyone else said. make sure they are all snapped in. sometimes when you have been staring too long stuff escapes you. when im like this i work backwards to look at everything differently. usually catch it that way
TIM Z
Screwed by 0087s
Jan 17, 2009
1,574
Navarre, OH
Does your Hypertech reset codes? Just wandering cuz i know nothing about the max energy.
Like was said go thru and re check your connections. I had my pan off twice when i did my JR kit. And theres not a lot of room around the wiring.
you'll get it!!:hug:
ruffmanatv
May 9, 2008
3,640
46
Van Wert, OH
Ok. Well I think I found it, but not sure. The solinode above the trim valve solinodes is cracked where it plugs in. I am going to take the valve body back out and replace this solinode.
Any idea where to pick one of these up?
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
allison dealer or chevy dealer .........
ruffmanatv
May 9, 2008
3,640
46
Van Wert, OH
Replaced shift solinode C today. Local Allison dealer had two in stock, Thank God. No more codes now.
Only question I have now for someone who had this, Is it normal for it to slip a bit between the 2-3 and 3-4 shifts and also the 5-6 shifts until it relearns?
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
you mean slip like the trans limps or kind of flares?
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Take it easy on it if it's shifting funny. Can you find anyone to reset the taps?
