I just got done changing my trans fluid, I did not do the HOOT method as it was dark and cold outside. I also changed the spin on. I was quite happy to notice that the fluid I drained out was just as clean as the fluid going in and smelled the same. I also drained out close to the same amount that went in. I now have a mix of DEX VI and Amsoil Torque Drive ATF. The truck has 49 000 km (30 625mi). I have run the Bully Dog Power Pup on the 70 hp setting, and the PPE on the 160 hp setting. The trans has never been limped.
My question is would I be able to get away with just a Transgo Jr and a Suncoast 1057 converter? My goal is to run high 13's next year. Do you guys think this will hold? Any help you can give me will be much appreciated. Sorry for the long post. Thanks.
