Transfer flow fuel tank sender values?
down_hiller
I just found a good deal on a 50 gallon transfer flow fuel tank with the built in tool box that came out of a 2004 dodge 3500. It came with the monitor that tells you how much fuel is in the stock tank as well as the aux tank. I was able to do some searching and find the dodge sending unit reads 10 ohms full and 240 empty. Does anyone know what the values are for the stock sending unit on an 02 duramax. I tried searching but just came up with mixed answers. If they are the same than I can wire it up to automatically transfer fuel like it is supposed to.
Thank You
