02 Duramax 6.6 4WD Tcase actuators is bad, is this a DIY job, or should I take it to a shop ?
Also I'm pretty sure the cases are cast aluminum not magnesium.
Sent from my D5803 using Tapatalk
Or, as has been recommended in the past by a few trans builders, 5w-30 synthetic engine oil and overfill by a 1/2 liter or so. Better cooling and lubrication than dex.
I believe I remember him saying it was all around better for everyone but that was 7 years ago or so now so maybe not.Mike says going with 5w-30 syn is best for those that do not get under their truck and check fluid level regularly or change it as they should. Dex 3 is still best to put in, just need to watch it if you have evap issues or run lots of miles
