So I have slight problem being I work at a gm dealer i was able correct one problem and suck the old fluid out with special machine we have at work and put new fluid in but not the other my wife's lb7 in my sig is the one I asking about I need suggestions on how to get the lower drain plug out last time I changed the transfer case fluid I didn't think about it and ran the aluminum drain plug all the way up flush being that's all I've done since I've owned the truck since 2009 and didn't think about the alumnium oxidation which siezed it in place now and when I went to removed it I used a 18mm wrench 6 point and it rounded off what is the best way to remove it so I don't have to purchase a new rear case half I thought about welding a nut to it or using an extracter but the aluminum is soft and I'm kinda at a lost as what to try next I even tried channel lock and locking pliers as well as air hammer with chisel to try and back it out with no luck anyone ever have this problem if so what is the best solution to fix the said problem thanks in advance
