To whom ever can answer, I’m currently rebuilding my transfer case I have been trying to track down what’s causing my driveline shake. I was under the impression that the input shaft bearing was shot cause it had a bunch of play but I looked closer and see that the bearing is actually moving back and forth in the c clip slot is this normal? The output shaft bearing had moved like this as well that’s why I question if it’s normal I took a video I’ll attach.
https://youtu.be/rhbgFuAGa-c
