Trans whining
dirtylb7
slowly but in the process
Oct 29, 2010
utah
What would cause my Trans to start whining is coming from bell housing tq converter pump area fluid is full just changed it and filters trying to fix it but that didn't help any thoughts or suggestion? Trans shifts fine no powa loss or anything just this annoying whining noise truck is an 02 lb7 stock Trans
dirtylb7
Oct 29, 2010
utah
No. It was doing it befor I changed it and even then it had the right amount of fluid in it
dirtylb7
Oct 29, 2010
utah
It's beyond normal. I have had 5 duramax's it's not normal. It's as if it were an old muscle car with posi whining noise trust me it's not normal
Tater
Built not Bought
Mar 9, 2012
Cresco, Ia
I had a problem like this with mine after they build it from a core it was in the rear of the trans and was the planetary gear. It sound like straight cut gears. So they just rebuild my core and put it back in my truck.
dirtylb7
Oct 29, 2010
utah
It's all the time can't really here it after 40 mph but it's still there if I rev it up in nutral it gets louder as well
dirtylb7
Oct 29, 2010
utah
So noise goes away if I start truck for 5 sec with pan drained. So I'm thinking pump but what will fix this problem or what is problem??????
dirtylb7
Oct 29, 2010
utah
Any input guys? Is it maybe the converter? I crawled under the truck again and it really sounds like the noise is from the converter I just want to be sure befor I pull the Trans down. I don't want to pull it put the new converter in and have the noise still be there any help on this matter would be great
