Allison 6sp: Trans slips a little around corner....
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
When I make a turn around a corner it will seem to slip a little, I let of roll thru turn and then it seems to lock back in. I let off throttle and coast thru turn, then after rolling straight, I can accelerate. Only happens just after I start driving, once I am driving it goes away. Only happened twice. I checked fluid and it took a full quart and a hair more to bring it to the good mark. I havent drove it yet, I will be heading out in a few.
Think that was the prob? Can 1 quart really cause this?
6 speed with SC IV and 1058 running Dex 6
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
i have not had it happen to me while cornering but i have had it happen when cold and found i was 1-2 quarts low , filled up and not a problem now . but mine would pop a check engine light with a pressure code ?
15,681
Sounds like low fluid. Was the fluid topped off after engine work. The radiator leaking out trans fluid is the biggest culprit and rarely does the tech ever check the fluid and top it off.
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
Honestly, I've done 2 spin on changes, Maybe the oil in the spin-on made it that low cause I have habit of just switching and not re-fill..... Also just looked, and rear seal must be leaking just a tad...
15,681
Rear seal you see is for the transfer case and should not have anything to do with the problem Mike. Call me if you need me.Cell # is in sig.:hug:
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
ROFL, DUR!!! Good point Mike. I wasnt thinking very good lol.
Thanks Mike. Going for drive now I'll let ya know how it goes.
